ISIS could not initiate a route walk for the specified protocol. As a result, export of the specified protocol may not work properly.
This is a symptom of low system memory resources. A less complex or scaled configuration may be necessary in order to enable exporting of the specified protocol. Reduce the configuration to free up resources, then disable and re-enable exporting of this protocol.
Error
failed to allocate route walk structure for route type %proto%
| Name | Type |
| proto | String |
